IE
4/7/2021 1:09pm
Can the silver part of the outer fork tube that contains the seals on later KX 125 forks be removed? It’s gotta be either threaded or pressed on?
Want to make sure before I go at it with heat or anything.
Did you ever get these apart I have the same question
I didn’t, I anodised the whole tube then polished the lower piece to remove the anodise and leave a good finish on the aluminium.
Edit: I do believe they are threaded, but after some trying I decided it wasn’t worth risking destroying the tubes.
Post a reply to: KX125 KYB outer fork tube question
