AT
Is it possible to replace the Crank Seal left Side (Flywheel Side) without splitting the Cases on
a SX250 2019 ?
a SX250 2019 ?
Isn't it possible to drive 2 wood screws into the seal and pull out with pliers after removing the bolt on part of the stator mount?
I'm not sure if you can or not on your specific bike but if it's one of the bikes you can, order a Lisle seal puller #58430 for $17 and then you don't have to worry about sending a wood screw or self tapper into a case or if any shavings came off the steel liner in the seal and made it's way into the bearing. It's one of the best $17 I've ever spent and recommend anyone doing it gets one too.
Thanks for the tip. Just ordered one.
Depending on the year, most of them require you split the cases. They either have the stator mount or a cast component to keep the seal from pushing/walking out.
Post a reply to: KTM left side Crank Seal replacement
