Waco, TX
12/21/2020 6:27pm
Does anyone know if KTM hubs are clear coated?
I’m rebuilding wheels with new rims/spokes and want to get the hubs looking good again while they’re apart. One of them is pretty hazy/oxidized compared to what they look like new, so I’m wondering if it’s the actual aluminum that’s oxidized, or if there’s clear coat on there that can be removed...
They’re off of an ‘18
Front is still looks decent
Rear looks like garbage
Any particular polish/method you recommend?
I planned on applying clear cerakote afterwards.
The pieces photoed above I would polish(like bench wheel polish) the dullness out of the center areas, and clean the cast surfaces on the sides to a near perfect and consistent result, and I would expected the center area to slightly dull from the polish finish, and the rough cast surface I would expect to be even more dull, a bit matte, from anodize. Consider the process slightly eats into the surface and mostly grows out, so tolerances will change as such when applying or stripping anodize. Stock hubs here are not anodized.
Post a reply to: KTM Wheel Hub Coating
