Hey guys, finally got my parts back and started putting the engine together. I’m stumped at this tranny instal with the shift forks and drum:
-I’ve double checked the correct orientation of the forks
-Checked the tranny shafts are put together correct
The problem I’m having is when it’s all together with the cases it shifts 2-3 times then jams up. I’ve tried so many configurations, but do you think it’s just cause the engine isn’t running?
I’m mostly confused on where the shift fork pins go into the shift drum, I’ve also tried starting with the shift star in neutral
Anyone who’s been in the bottom end have some advice?
It’s all layed our pretty simple just can’t figure out if I’m missing a step?
