1/16/2019 9:44 AM
Edited Date/Time: 1/16/2019 9:53 AM
aaron63 wrote:
Hi,
I just bought a second hand trax shock. I've installed it and it seems to have a slight knock when lifting the bike up from the back, as if the bushings are gone. But when looking at the bushing there is no play in them. is this just the trax feature and is pretty normal? or should I be looking at getting the shock serviced, although it was done 6hrs ago according to the previous owner which he gave me his receipt for proof.
The bike is a 2018 sxf350 with only 18hrs on it so linkage bearings are all fine.
So...I'm not sure what "internal springs" some of the users here are talking about.
There are some coil-compression springs in this shock, but nearly all shocks use them. And compression springs don't normally break.
But...perhaps there is something about this shock where "the springs: were a problem.
With that....I'll add this.
Often bushings look and feel perfectly fine but still end up making noise when the forces applied via the swing arm are there. So...this could be a bushing or bearing thing.
Secondly, WP often uses what is called a "top-out" spring in their shocks, and they are beefy. This is a short but large spring that sits on top of the seal head that cushions the blow when the shock goes to full extension. Some shocks use a spring, other shocks use a hydraulic top out. Now...what matters here is that the top out spring counters the effect of the main spring when the shock goes to full extension, meaning the shock is not as tight at full extension as other shocks. That can me the movement coming off of full compression is soft.
You could measure for this by putting a zip tie on the shaft, with the bike on the stand, and then seeing how far you can compress the shock by pulling up on the tire with your hands.
NOW...that said, if this is not a bushing or bearing problem, what I really think it might be is free piston top out. I say this because I often open up a lot of recently serviced WP shocks where the free piston is knocking against the top of the reservoir when the shock goes to full extension. This means at full extension, the pressure in the shock is zero, giving the top out spring even more effect, (F=PA against the area of the rod).
This is because the service person did not properly set-back the free piston before filling and charging the shock, made all the more likely when service dudes use shock pumps to purge trapped air. And...free piston top out is way more noticeable on a WP shock because of their big top out springs.
Is that making any sense?
You only get this problem with free pistons, and not with bladders (but I do prefer free pistons over bladders). So does Ohlins.
Bottom line, I would not ride the bike until you fix this because if it is this, then the free piston is hammering against the shock body each time the shock goes to full extension.
