- Pick trends
- Create a private league
- And more!
Main jet 500
Pilot jet 32.5
Slide 5.75 (Kawasaki part#16025-0003)
Needle 43-75 (KTM part #55431134400)
Clip position #3 with the colder temps
Needle jet S4 (KTM part #55431021400)
Air screw 1.5-2.0
Fuel 55:1
Until recently (at 14 deg. C) I used a setup based on your commendations that worked very well:
MJ 490
PJ 35
Slide #5
NDL 43-75
Clip position #3
NJ S4
ASO 1.75
Oil/Fuel 1:32
At 3 deg C. I changed to:
MJ 500
PJ 37.5
NDL 44-75 at clip #3 (1/2 clip richer)
ASO 2.0
Bike still runs great, but when I changed the plug by a new NGK BR8ECM, the plugs' isolator stays quite white, also with a #9 plug. Looks (too?) lean, but maybe I worry for nothing, that's why I'm curious about what MJ others use at low temps.
38 pilot
NECJ 3rd clip
2019 sx250 with boyesen rad valve
I switched to a keihin from a 2016 sx250 after i had nothing but issues with my mikuni
I ride mostly sand in south west scotland
Leave the jetting you have in it and put a 500 main in it and see how it does. I personally like the bigger mains in these bikes as it picked up some over rev.
Another thing, I run my jetting at 55:1. With you running 32:1 that’s less gas and more oil, which will lean out a bike. Maybe with the 500 main back it down to 40 or 50:1 and see what the plug looks like and how it runs. I’ve done a lot of hours with 55:1 and had excellent wear on the piston so I wouldn’t be concerned with running less oil. Synthetic oils have come a long way.
I'll stick with the 500 MJ for the time being, maybe richen the needle a bit, and keep a close eye on everything.
About the oil/fuel ratio: We've used 1:32 for all of our bikes, starting with the SX50 15 years ago. I prefer to make a mixture richer/leaner by changing the jetting, not by adding/reducing the amount of oil. The effect of changing from 1:32 to 1:40 is also very small:
1:32=> 97.0% of gasoline per volume of mixed fuel
1:40=> 97.6% of gasoline per volume of mixed fuel
The difference between the two is only 0.6%, or, with 1:40 you will be only 0.6% richer than when using 1:32.
- Oirschot
- Budel
- Berghem
- Veldhoven
- Eersel
Less:
- Boekel
- Son
- Stevensbeek
- Reusel
- Lille (Belgium)
Also, 1/40 with good quality 2 stroke oil is good & safe.
Espescially with the fully synthetic oils we have now...
The 43-75 needle that AJ uses 1/2 clip position richer than the 42-75 needle. The 42-75 needle in the same clip position as the 43-75,is going to be a little more responsive down low. Is it worth it ? It's up to the individual rider. It's all about having options.
The Lectron carb is not going to have the same hit as the Mikuni, it typically has a smoother type of power delivery. it may be an option for someone who rides at varying altitudes.
Lots of testing. I try to get guys/gals in the ball park jetting wise, but the final setting are up to the riders. I try to provide knowledge as to how to get there.
I’m am going to point out that the jetting is crisp and the 250 runs like a 250 should. A lot of people find it very violent with the on/off switch type of throttle response. It’s super rideable tho and I love it, power whenever I need it.
Got AJ specs on my 19TC250 and snappy (read violent!) is on point.
I am going to richen this setup and play more with the powervalve to tame it a bit.
Nevertheless , the bike runs great, no gargle or hiccup
No longer affected as temp/humidity change
It is running like a 250 should .. and for the fraction of the cost of a Lectron or Keihin (not bashing, I met people who switched and like these carbs)
Looking for a baseline to start from. Currently temps are between 3 and 6 °C (37 and 43 °F).
2018 KTM SX250
- HGS Pipe
- Ozzo reed assy
- Only (deep) sand tracks
What MJ do you use in these condition?
VHM head with higher compression insert (still using 98 fuel)
1.4mm squish
PPS exhaust
Vforce 4
NGK iridium #8 plug
480 main.
Sandtracks
Also rider dependable, fast rider will need richer jetting than slow guy.
So if you have doubts about your jetting check your engine, plug chop, piston wash,...
Or go to reputable shop...
Post a reply to: KTM SX250 Sand riders: What MJ at colder temps?
