minikx
12/28/2020 1:55pm
12/28/2020 1:55pm
4/28/2021 11:24pm
Hi guys
Just bought my 4 year old a KTM 50, he's got a PW 50 aswell. The KTM is just too much for him at the moment. If I adjust the clutch to the first few clicks will it make it rideable. Or is there a way of restricting the throttle too? Someone in local bike shop said something about jubilee clip and piece of metal
Cheers
Cheers
check with dealer
https://brappowersports.com/product/exhaust-restrictor/
He was real little when he started on the mini. He was on his oset for about a year before I pulled the trigger a little early on the 50 mini 3 months before he turned 3. One thing I was researching was a wireless kill switch so I could shut the bike off if he got himself into a wiskey throttle scenario but he was excited to get right on it after i brought it home so that never became reality. The new clutches on the ktm are really a game changer.
Thanks for reply
And so little there
I tried my boy on standard setting, way too much power for him
I've now put it on 3 clicks
And also a homemade throttle restrictor
I put a clip around the throttle grip with a piece of metal out the front so it Hits the break lever before full throttle
I will be patient and every now and then do a click on the clutch and a bit more movement on throttle restrictor
Thanks for the replies
I just hope 2021 is a little different so we can have more ride time
Your PW50 has that same thing in it now unless you removed it already, it may fit.
Good luck-
I started my son on a KX65 moving from a PW80 last January using the washer in the pipe method and it worked perfectly. By the end of Feb I removed the washer. Almost 1 year later were on YZ65 and he's worked his way towards the front of the pack after starting to race in July.
He has an oset Mx 10 which is ideal both at track and local fields
I want to get him back on the KTM
The exhaust restrictor is out of stock
Any ideas what size washer I would need to fit between exhaust and engine
Thanks
I've had carb problems on other bikes when I've put inserts in
I tried last night to take exhaust off
There are 3 bolts on exhaust flange going onto cylinder
2 I got to the 3rd seemed impossible
Any advice please
@XC706 what Ktm 50? Used to be junior senior now it’s sx or sx mini, my son is on a pw and I want to up him on bike size, but don’t know what ktm to get, I feel like the senior is too big
Please tell me, what was the inner diameter of this part?
I made a restrictor for the exhaust with a M16 stainless steel washer, with some 19mm stainless pipe welded to each side. Similar to the picture below. It wasn't in long and then it came out and he managed the power
Thanks!
Post a reply to: KTM SX 50 MINI - Restrict
