KTM SX 125 stuck in first gear
3/30/2018 12:46 PM
Edited Date/Time: 3/30/2018 12:47 PM
My KTM SX 125 2013 is stuck in a first gear, when I'm trying to shift into second gear it ends up in neutral, you can hear a 'click' noise from neutral gear but nothing clicks when I'm trying to shift into a second gear. Can you guys help? Is it some spring stuck or something?
3/30/2018 9:39 PM
Edited Date/Time: 3/30/2018 9:40 PM
It sounds like you have a shift drum issue. Could be a broken spring or faulty other parts in that assembly.
3/31/2018 6:05 AM
I think paw paw is right about broken spring on the shift shaft assembly you still need to remove the side case and the clutch to inspect.
