AT
KTM Two Stroke
12/31/2017 2:40am
12/31/2017 2:40am
1/5/2018 2:56pm
When i replaced the Piston from my 150 KTM
this Year in May i noticed that the New Piston was 0.6mm
higher than the OEM Piston.
It was a bit strange to me but i stack one more
Basegasket under the Zylinder and the Dimension X
was OK.
Last Week i Order a new Wössner Piston again and it has the same size like the OEM ???
I measure from Piston Top to Piston Pin Top
22,60 to. 22,00mm
Has anybody Seen this before on another Piston Manufacturer??
Write an E-Mail to Wössner but they are on Christmas Holiday
was OK.
22,60 to. 22,00mm
and on the Picture you can See the Pin was in both Piston inside, and i have a difference from 0,6mm
It was the same Piston Brand with the same Ordernumber.
That is what i can not understand??
Anyways buy OEM, Wiseco, JE, or CP pistons and nothing else. Theyre all very reputable & make solid shit.
I know that a normal Manufacturing Tolerance is in the 0,01mm Area.
As i said i write an E-Mail to Wössner to claify this Problem.
Post a reply to: KTM Piston Height
