Boise, ID
3/21/2017 3:19am
I am changing all the fluids in my 2014 KTM 250 SX. Right now I'm out of oil so the transmission is empty.
I have been working on the hydraulic clutch and changing the fluid. I was able to change the fluid fine just like I did the brakes, but I noticed after I was done that with the clutch engaged and the bike in gear the rear wheel will not spin. That tells me the clutch isn't working. I then took the slave cylinder off like in the Transworld video linked below. I followed his procedure for back bleeding and it looked good to me. I could even pull in the clutch and feel the piston moving. I put it all back together but still the rear wheel can't move with the clutch engaged. Is this normal when the bike has no transmission fluid or should I dig in more and investigate possible problems with the master cylinder?
Thanks for any help
Transworld video below.
https://www.youtube.com/watch?v=lZIb0Vya5p4
Thanks for any help
Edit - Anyone had any luck with the loctite stripped thread repair kits for bolts like these?
Edit 2 - Another option I read about is putting a full thread stud in with red loctite and then just buy a nut. Since it isn't fully stripped and this bolt doesn't need a lot of torque this could probably work.
It being hard to thread in was because the end was boogered up. You could have potentially cross threaded or boogered up your nicely done insert job.
But you didn’t and sounds like it’s stronger than ever now. Just an idea for the future. You can run the nut past the cut over and over until it goes by hand and then take a file to clean up any sharp edges if need be.
Just out of curiosity is 133 your race number or do you have a 125 that's had the cylinder bored out?
Post a reply to: KTM Hydraulic Clutch Issue
