I’m currently running a vortex ignition which is absolutely brilliant but the dam bike will not start with it, I have to plug my standard one in to get it to fire up but with the vortex it just turns over and doesn’t want to start.
Once it’s warmed up it will start with the vortex but not very well and is bit hard on the battery.
I’ve done the TPS
I also put my vortex on my friends brand new bike and it fired up straight away so I don’t think it’s the vortex.
I’ve also changed the fuel pump relay.
Any help would be great.
Thank you
I’ve done the TPS
Thank you
Obviously the mapping on the vortex is leaner which is why it doesn't want to start cold but will start hot. Perhaps your coolant temp sensor is bad and not sending correct info to the ECU to richen up for cold starting.
I’ll have to check the temperature sensor, where will I find this ? Thanks
before buying something you can't return
Post a reply to: KTM 2019 250SXF won’t start with Vortex ignition!!
