Cairo, GA
I have a Kawasaki KLX 140 that I use as a pitbike. While riding last week my bike started cutting out. I thought I was about out of gas so I pulled in. I added some gas and it started pouring out the carburetor's overflow lines. Great! I guess my float is stuck so I need to pull the carb and check on that.
But this got me to thinking about going ahead and doing a carburetor swap. I know several members at Thumpertalk have reported good results by replacing the OEM 20mm Keihin with a 24mm Mikuni from a KX65. I was just wondering if anyone here had played around with a carburetor swap on one of these?? I see that this mod is also popular with Yamaha TTR 125 owners. I've been looking on EBay and there are a few used 24mm Mikuni's from KX65's and also a ton of cheap Chinese clones that are even cheaper than the used carbs. Does anyone have any experience with the Chinese clones? I know I had a Pitster Pro once that never had any carburetor problems (other than needing to have a richer pilot jet installed).
I'm currently running a cone filter on the tm28 but I do plan on modifying the stock air box so I can tie into it vs pulling hot air from around the exhaust.
I got the tm28 from engines only.. but it had a 15 pilot and 210 main in it. The 15 is okay, but the 210 was a million times too rich. I'm at 8500' in Colorado so I've backed the main down to a 135 and it's as crisp as it's ever been.. light years ahead of the stock carb.
Post a reply to: KLX 140 carburetor swap
