Cleveland, OH
Been looking at these for a while and really like the concept. Going into a set of KYB SSS. Based on my experience you could probably swap these out without replacing the oil. Flip the fork and pull the bottom leg, keeping the oil in the top. Then again may be better to just change oil for simplicity. Wondering about the performance too? Anyone been using these or installed a set? Thanks.
https://www.google.com/amp/s/motocrossactionmag.com/amp/fork-works-ride…
I was looking to smooth out some of the mid stroke and gain a bit more confidence in the front end feel, which I like pretty well at the moment, but I know could be a bit better. Feels like when I soften up I get more bite, but not enough hold up, when I click in compression wise I get the hold up, but the it pushes.
You are correct in the fact that the perches do have a smaller hole and a shim as well, so while I understand the concept I guess its all based on the oil level really in how well these perches perform? Otherwise they would ramp up quickly as you stated.
Post a reply to: JBI Pro Perch 2.0 whose got experience?
