Intermittent starting/Delayed Kill switch.
6/19/2020 4:24 PM
Edited Date/Time: 6/19/2020 4:25 PM
Hello all, I have a 2017 KX250F PC built bike, has full motor build and GET electronics ignition/mapping. The issue I am having is the bikes kill switch has about a 4-5sec delay before the bike dies. I replaced with a brand new oem kill switch and still same problem.... Also, bike will start perfect hot or cold no change and then out of no where it won't even try to start... wiggle wires, push kill switch button, ect... and then bike will start perfect. Not sure what is going on here, new to the FI system and there components. Any feedback is appreciated. Photo
6/19/2020 9:07 PM
Edited Date/Time: 6/19/2020 9:09 PM
check and clean all connections an ground wires
possible moisture in buttons use wd40 and air to blow out
6/23/2020 5:14 PM
I have checked/cleaned.... nothing jumped out at me. Bike only has 15hrs on it also.
6/23/2020 7:10 PM
Try going back to the stock ECU if you have it. I've heard of some weird issues with the GET ECU's
6/24/2020 6:15 AM
Thanks DynoDan22, I have the stock ecu, I could try that, I just didn't know if it would be safe for the "mod" motor. Also, motor/ecu/FI sys is tuned for MR Pro 6 fuel.
