How to split ktm65 2012 fork.
12/2/2017 7:48 AM
I wanted to change the seals and oil, seals no issue, but I am struggling to break the internal fork to replace the oil. Is there any trick to it or is it brute force. can't find the recommended KTM tool T727 anywhere, I got an industrial pin wrench but it's still not budging. There is no bolt at the bottom of the fork. Please see pics. HELP! Photo
12/2/2017 9:57 AM
12/2/2017 12:25 PM
You have to heat the crap out of the tube to break the ungodly amount of loctite they use when they put it together at the factory. Over the years I have actually sheared off the pins from two different tools. Seems they stopped using so much on later years as the newer ones are easier to get apart.
12/2/2017 3:48 PM
X2 heat
