How to find parts for Showa A-Kit?
1/25/2018 1:17 PM
I have an old a-kit shock from showa for my cr250-07. It's quite beat up so I want to refurbish it.. but I can't find any spare parts lists or anyone that seems to offer parts online? KYB seems to be much easier to find spares to.
Any advice?
1/25/2018 3:42 PM
Have you tried contacting Showa directly? I'm sure someone like Factory Connection could get what you need too.
1/25/2018 11:07 PM
Yes it seems like the only way to go. Id like to find an exploded view with a parts list, but I guess I wont sad
1/26/2018 6:28 AM
Try jgr
1/26/2018 7:10 AM
Seals and bushes are the same as 1996-2000 RM 125/250
1/26/2018 8:09 AM
Racing suspension products on east coast. Craig can source hard parts, and may have some in stock.
1/27/2018 3:03 AM
All right! Thanx!
1/27/2018 3:04 AM
Will do! Thanx!
1/27/2018 6:26 AM
rostocker wrote:
All right! Thanx!
I did a little research regarding the RM shock.
On my shock there is a 18x50 shaft/cylinder and that's the same as the RM125/250 2001-8 RMZ250/450 2005-9
Any input on this?
1/27/2018 7:52 AM
When I said 96- 00 RM I was talking about the forks. Regarding the shock RM 125 2004-2008 is the same and I'm sure RM250 and RMZ250 / 450 with 18mm rod are the same. If its just the rod seal you need then the KYB and late model KTM with 18mm rods are the same.
1/27/2018 8:44 AM
karlz wrote:
When I said 96- 00 RM I was talking about the forks. Regarding the shock RM 125 2004-2008 is the same and I'm sure RM250 and ...more
All right!
Yes that and some cosmetic parts (like the anodized parts on the compression adjuster)
Now that I know what to use regarding wear parts that's no problem anymore. However the BIG oversized comp adjuster is my main concern now. I would like to change the visible parts there, but I guess here I need to turn to a shop.
1/28/2018 7:59 PM
Try SDI
