Denver Metro, CO
I am setting up a new bike and have never tried going tighter than the bars instantly flopping to either side. I usually tight the bearing preload nut just to the point where I notice the slightest drag, then I back off a hair.
On this new bike, she's a bit touchier than my other bikes. I tightened the bearing preload nut as usual, but the top triple clamp nut has waaaay more of an effect on steering "freedom"/bearing compression than other bikes I've owned when tightening it. The steering readily sweeps side-to-side, but there's just a hair of drag.
Wondering what you guys typically recommend.
I know some use the bearing preload as drag to avhieve a damping effect ("poor man's steering damper"), but how tight is that ... seems awful tight.
Any real-world feedback on bearing tightness vs. bearing life?
I learn a lot from discussing these "mundane" aspects of bike upkeep.
Thanks for any input!
At 4m:57s Michael Lindsay describes his personal tension preference.
Post a reply to: How tight do you guys tighten your steering stem bearings?
