How do I remove this bearing?
10/10/2017 11:50 AM
There's no way to hit or press it out from the back like I usually do. So how am I supposed to get it out?Photo
10/10/2017 12:25 PM
Edited Date/Time: 10/10/2017 12:27 PM
Youll want to get a bearing puller set and a torch. Heat up the case and utilize the puller and it will pop right out. You might be lucky enough to heat the backside and tap it with a deadblow to get it to fall out. Heat the aluminum to 220 degrees for best results. A good test is to heat it and drip a drop of water on it. If it evaporates instantly its hot enough. Dont go too much hotter or you will warp shit
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
10/10/2017 1:07 PM
Yep warm the case and it will fall out
10/10/2017 1:54 PM
Heat the casing up and the tool you need is called a blind bearing puller.
www.karlzracing.com
10/10/2017 1:58 PM
www.karlzracing.com
That link just took me to the home page
10/10/2017 2:37 PM
That link is my signature not a link to the tool. You can buy the tool on ebay or motor accessory store.
www.karlzracing.com
10/10/2017 3:18 PM
If you don’t want to buy a puller set, autozone has them on their tool rental program (you buy the set, then get refunded when you return it). Just used one for my CR’s rebuild.
10/10/2017 3:25 PM
Put the case in the oven 15 minutes at 300deg and it will fall out
10/11/2017 8:56 PM
If heat doesn't work and you can't get your hands on a bearing puller, try the grease packed rag method.
2019 KTM 350 XC-F
10/11/2017 9:02 PM
The what method? Please explain...
10/11/2017 10:30 PM
IG @jaredkeller96
10/12/2017 8:02 AM
Get one - https://www.rockymountainatvmc.com/p/989/20342/Tusk-Bearing-Remover
It's the right tool for the job. You may not use it all the time, but when you do youll be glad you have it.
10/12/2017 11:04 AM
It's the right tool for the job. You may not ...more
Yes!
I have that exact set and it is great.
10/12/2017 8:57 PM
Notice in this video it is a shielded bearing. That retains the grease pressure behind the bearing. The bearing in the motorcycle cases is fully open. You might get lucky if you pack enough rags in there but most of the grease would probably just push through the bearing. Anyone ever done it successfully on an open bearing like this?
Powerband in every gear !
10/12/2017 9:37 PM
jaredkeller96 wrote:
FGR01 wrote:
Notice in this video it is a shielded bearing. That retains the grease pressure behind the bearing. The bearing in the ...more
That is probably what would happen. Still might be worth a shot if he's waiting for a puller to be shipped. Worst case you make a greasy mess
2019 KTM 350 XC-F
10/13/2017 9:27 AM
seth505 wrote:
Yes!
Harbor Freight has those for $69
With really small bearings that are too small for the tool to fit in, pull the bearing retainer out of the way, push all the bearings to one side and pull out the inner race. The remaining outer race can be removed with the slide puller.
10/16/2017 8:00 AM
Do it right and buy this...takes 30 seconds to pull bearings
KTM 350 XC-F
IG - @mattman122
