Warwick, NY
No paperwork on this so I'll ask you guys.
The dots to align to the head on exh cam have 2 dots plus the 12 o'clock dot
What's the difference between the 2 head alignment dots. I'll call them upper as in 10 o'clock and lower as 9 o'clock.
One for bottom to mid and the other for mid to top end ?
I'd like to know which does what.
Thanks
Thanks
Yz450 quads used to use a 1 tooth change to get to the bike powerband setup to boost top end
Will use the longer duration dot. But yes, stage 2 exh has 2 different dots (power choice) on the sprocket. I will shoot the pic myself when I complete the ceramic bearings install
Curious why Hot Cams did that.
The outer is my alignment. Too bad Hot Cams could explain that in this simple fashion. Messed with my head trying figure those other 2.
Post a reply to: Hot cams Stage 2 exh with 2 different timing Mark's????
