PL
4/15/2019 5:17am
Hi guys, did anyone have a similar problem? I completely rebuilt my RM 250 2005 last year, and the Hot Rods crankshaft bearings fell apart at 20 hour mark, destroying the crank in the process (deep notching). I alwas use motul 800 in 1:32 ratio. Damn I am bummed.
Hod Rods/Pivot Works are junk. My torn shoulder wishes i sprung the extra $100 bucks of OEM
I was surprised, a complete crank and bearings from RMATVMC was $350 for my YZ250. It wasn’t that much more than a Wiseco or Hot Rods bottom end kit. Would have been like $275 if I had gone with them.
Hot Rods 2 stroke cranks are good if installed correctly.
Thank you for the input gentlemen, I am going OEM on the bearings this time. Just a bummer I need to fork out for another crank...
Had another OEM set for the same engine. They were sloppy out of the box. Crank had excessive up and down movement. Had to jerk it back apart. Called it a day, and got some C3 rated FAG bearings.
You could not have given me another set of those OEM Yamaha bearings.
It's not like OEM cranks or bearings never fail prematurely????
Like above I usually spec bearings from a trusted source. There are only a few odd sizes that truly need to go OEM because it's simply to much hassle verses savings to track down the specific size. Usually transmission bearings........
Post a reply to: Hot Rods Crankshaft bearings failed at 20 hours
