Apple Valley, CA
5/17/2018 4:29am
I have a 95 CR500. Perfect running bike that I ride desert with. Been hesitating breaking down the bike for a frame repair and full resto while in the process.
Bottom side of frame has a rust through spot on both frame rails. What’s your opinion on fixing and what process would you use to repair it?
Frames do flex, especially steel ones, and I wouldn’t trust a cut and welded section to hold up to any big jumps or crashes.
Here is a frame I had repaired ....include the engine mounts bolts so the welder can align the rails when welding.... I also make my own skid plates for the chromoly frames, very ez to do & having the skid plate welded in also strengthens the lower frame assy... If done correctly you will never have to do it again....
Thanks for the info and pictures....Doug.
Post a reply to: Honda CR500 frame rust/cancer.
