Could anyone help me out. I’m looking at buying a Keihin PWK carburettor for my 2003 Honda CR 250 but do not know the exact carb I need?
Long body 91 mm from a 2000 CR250 or 99 model will be your best option. The 99 had a richer slide than the 00 model.
JD Jetting is a great source for these carbs. They’ll include a jet kit. I think they are about $270. Not bad when you consider the jet kit is $80. I just put one on my 2004 CR250. It has never ran better.
I’ve added a link to an eBay item. Would you be able to tell me if this is the correct carb? Many thanks for your help
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F263753601813
Edited Date/Time:
That appears to be a screw top Keihin carb which is the older style that fits the 02-03 CR2. It's a 39mm which isn't a bad thing, but the 38mm is the popular choice as it will give better lower end response.
I'd suggest emailing the seller & ask if it's a PWK quadvent. That's the good one IMHO.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F263753601813H4L wrote:
Thanks very much. I don’t know much about them so appreciate your help. The seller has 2 other keihin PWKs. Is the short body the one I’d need? Linked that below
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F263753590092
No, as BR8ES mentioned. That is the short body Keihin with tps that works better for the 04-07 CR2 models.
Edited Date/Time:
These are the Keihin PWK A/S carb that would work best on the 02-03 CR2..
https://www.ebay.com/itm/Keihin-PWK-38mm-Airstriker-carb-Honda-CR250-01-07/332765338464?epid=15015795969&hash=item4d7a5c1b60:g:5IgAAOSw5U9ZjNc3
https://www.ebay.com/itm/Keihin-PWK-38mm-38-mil-Quad-Vent-Air-Striker-Carb-Carburetor-TRX250R-CR250-LT250/191852479906?epid=10017014739&hash=item2cab4c85a2:g:XloAAOSwxYxUw--6:sc:USPSPriorityMailPaddedFlatRateEnvelope!95124!US!-1
