Is there any tips on where to install the holeshot device on the fork guard? How does one determine where it should go? Can u put it too low? Usually I just figured almost as far as we can set it?!?
It is a balance. The more you lower the front, less traction on rear you will get. Also run the risk of not releasing the holeshot device if it is a fast sweeper.
We have a works connections. I know they all have info but I know everything is customable, lol, and just wondered how and or why they picked their spot. I just don't wanna buy a few fork guards to try different spots but then again maybe I will...
Its all about what you like. Some like it very low and some are so high it is hardly doing anything except holding the front still. Unless you purchased used, the template that should have came with the device will be your best bet.
