I need a new clutch in my ktm 350. Is it worth the extra cash for oem or Hinson over a cheap brand like tusk? I'm 180 lb B rider so I'm pretty hard on stuff and I need it to last.
OEM basket should be good. Tusk plates work good on my Hondas, and have a set waiting for my KTM 150.
Side note: there was a county official long ago named Jackie Moff.
I have also used Tusk kits in both my 450 and 125 with no complaints at all, seem to last just as long as other brands ive used.
Id go with oem or hinson. I strongly advise against putting chinese stuff in your motor. Tons of people have good luck with namura pistons but look at how many peoples bikes blow up as well. Ive never had any problems with oem or hinson plates.
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
I'm really impressed with Hinson clutches. It's a bit extra but their parts are bulletproof!
X2 Love mine! What about a Wiseco basket with Hinson plates, fibers, and pressure plate? It would be a bit cheaper
RTFM & AYFV
How many hours do you have on your clutch? I just got a 350 and curious how many hours you're getting out of it. I got 50 hrs out of the stock plates on my 250sx and could have gone much longer. Basket didn't have hint of a groove or discoloration. Something to be said about the steel baskets. I would also check and see if the 2018 plates are compatible because they have a new coating on them that is supposed to wear better with the steel basket. Read it in mxa this month.
buy a quality part. saving $100 isn't worth the price of a cheaper part if it fails when you're spend time recovering form injury. just my .02
Wiseco basket and plates are good in my experience. I've owned 5 Suzukis, so I know all about worn out clutches
17 CRF450,stock clutch had to adjust play a couple of times each moto outing.
I put in a Hinson clutch plate assembly, and zero fade, better modulation. Excellent product!!!
The Hinson plates never seemed to perform any better for me. They did last longer in Kawasaki's than stock, but not really in hondas or KTM's in my opinion. Their aluminum pieces are awesome though.
As for a tusk, I put one in one time because I had several Rocky Mountain gas cards so I could save my money for a trip to southwick and red bud. The clutch started slipping in the first practice at southwick, and when I pulled the set out, 2 plates were broken. Never again.
DP makes an outstanding clutch kit, very durable, hooks up great, but did have a weird engagement point.
It's very hard to improve upon the ktm clutch.
Wouldn't surprise me if both Moose and Hinson contract the same production facility for manufacturing (I know this is super popular in the helmet industry) however the specifics of the raw materials being used as decided by Moose, Pro-X, Hinson, etc can still vary; and in this case I believe most likely does. Not all metals and coatings are the same. But yeah, most people would be baffled if they knew how many different brands (from consumer products to moto stuff) all come out of the same factory.
F150Motocrosser wrote:Wouldn't surprise me if both Moose and Hinson contract the same production facility for manufacturing (I know this is super ...more
Yes. I've witnessed this at a factory back east through the corp I work for in the automotive industry.
ktm-5 wrote:I've heard that moose clutch baskets are made on the same assembly line as Hinson and given moose name. I've always had great ...more
Doesn't Hinson make all their own products in house?
If you skip to 5:30 you can see the machine process:
http://m.vitalmx.com/videos/features/Behind-the-Scenes-A-Candid-Look-at-Hinson-Racing,13773/ML512,13480
CarlinoJoeVideo wrote:Doesn't Hinson make all their own products in house?
...more
IDK about Hinson & moose manufacturing products at the same plant / warehouse. I was responding to F150Motocrosser's post about a couple of company's using the same place, but using their own materials. In my case I have seen different manufactures use the same plant that used different substrates to make the same product. It was interesting to see since they are competitors.
Have a 6 spring Hinson clutch kit on a 10 CRF450r & it has been bullet proof in comparison to the oem 4 spring unit. Will be using one on the CR when it's due for a replacement. Personally wouldn't even consider a Tusk or any cheap aftermarket unit.
H4L wrote:Yes. I've witnessed this at a factory back east through the corp I work for in the automotive industry.
...more
I'm not sure exactly, just my dealer had said Hinson makes the moose baskets also. They may use different material idk.
Basically all Moose products are made by someone else, but they team up with them to make their normal products with the Moose name on them. For example: Moose pistons and rods by Cp Carrillo, Moose valve train by Kibblewhite, Moose shifters and brake pedals by Hammerhead, Moose carbon fiber pieces by Eline, Moose enduro armor by Enduro Engineering, etc, etc, etc... So it is very possible for Moose to have a clutch basket made by Hinson!
I had 165 on my '11 350 when I sold it. Basket and inner hub looked new, clutch plates were still in spec.
Previous owner put Tusk plates in my KX250 smoker, clutch fades terrible when I get into tight hillclimbs...or whenever you beat on the clutch a bit. They are going right in the dumpster when the bike gets framed this winter...
I rode my brothers YZ 125 with Tusk plates this past weekend. While it started out pretty good it faded bad.
