Blew my rear wheel to bits over the weekend and need a wheel for this coming weekend. Have access to a 2012 Yz250 rear wheel, will that fit my '15 Yz450f? Are they the same size axles etc and will i need the 450 spacers or 250? Cheeers
I believe the 450 got a larger rear axle around 09 or sometime. If you can't find the info here, maybe search thumpertalk to double check. Good luck
Just use the 250's axle and axle blocks, it will get you through the weekend just fine.
I had a 250F swing arm on my 125 and used the stock wheel.
