Piedmont, SC
Ok I’m at around 800 ft elevation and the temp is around 70 degrees I’m looking for a starting point. Right now I got a 42 pilot 168 main and the stock Honda needle in the 3rd position. On the top end it cuts out ever so slightly. I don’t know if I need to raise the needle or what. I’m sort of lost. I just put this setting in before I had a 170 main and 45 pilot and it was rich off bottom but eventually I could get it to clear out.
NorCal - 32:1 HP2 premix, 0-1 K elevation, relatively no humidity, 70-90 deg. temps.
45 PJ
175 MJ
00 oem needle - A715/289R
3rd clip position
#7 slide
76 station 91 octane
Note: I tend to run the jetting a bit on the rich side for precautionary reasons.
needle part # https://www.partzilla.com/product/yamaha/4SR-14916-EJ-00?ref=51b86dc335…
Post a reply to: Help w/ 03 cr250 air striker jetting
