Help me ID these forks (KYB/Öhlins?)
12/21/2018 11:59 AM
Found these forks for a reasonable price. They have been on a 16 YZ 125, they seem to be stock KYB SSS forks with coatings and Öhlins TTX cartridges. Or am i wrong in this? What would you pay for them? And i assume they would fit a 2018 YZF 450.
12/21/2018 12:14 PM
Edited Date/Time: 12/21/2018 12:15 PM
If they were on a YZ125 they wont directly fit any of the 14+ YZ 4 strokes because of the axle diameter and where the upper clamp mounts is a different diameter as well. But that can always be fixed.
12/21/2018 12:24 PM
Jterry wrote:
If they were on a YZ125 they wont directly fit any of the 14+ YZ 4 strokes because of the axle diameter and where the upper ...more
Thanks, i thought it would've been the same for the 4-strokes!
12/22/2018 3:52 AM
Seems like they are built by kumlins suspension give him a call.
http://kumlinsmotor.se
12/22/2018 6:50 AM
Kyb factory lugs (older, cast model) and lower tubes, not sure about the uppers but my guess would be KYB anodized gold. Cartridges are pretty obvious wink
12/22/2018 7:09 AM
Edited Date/Time: 12/22/2018 7:14 AM
Turbojez wrote:
Kyb factory lugs (older, cast model) and lower tubes, not sure about the uppers but my guess would be KYB anodized gold. ...more
It sucks that they don't fit the YZF 450... I would've been able to buy these for almost under 1k!
12/22/2018 8:44 AM
You can open up the upper clamp on YZF and run the old style front axle and wheel or change the upper tubes for newer style. Maybe open up the fork lugs for the bigger axle? Not sure if it would be worth the hassle though.
12/22/2018 9:05 AM
Turbojez wrote:
You can open up the upper clamp on YZF and run the old style front axle and wheel or change the upper tubes for newer style. ...more
Yeah i don't think it's worth the hassle, well the hunt for some trick forks continueslaughing
12/22/2018 9:17 AM
Edited Date/Time: 12/22/2018 9:38 AM
What's wrong with your current stuff, or is the wallet too thick again? laughing
12/22/2018 9:21 AM
Nothing wrong at all hahalaughing Wallet is a bit too thick after the tax returns wink
