Landenberg, PA
9/10/2020 9:30am
I'm trying to figure out if these triple clamps will fit my '19 YZ250f, 22mm offset. I checked all the part numbers on Neken's site but nothing matches up. According to their info, I want:
YZF 250/450 2014-2019 22mm Neken part# 0409026 Parts Unlimited part# 0603-0591
The set I'm trying to determine are from a YZ450f but the part numbers don't match anything, even went through all their different bike applications.
one clamp say:
0401023-22
041 15
The other :
0402016-22
350 14
one clamp say:
0401023-22
041 15
The other :
0402016-22
350 14
Do you have anything out or coming out like these? Your customer service has always been top notch!
We'll have split yamaha clamps coming out relatively soon, but not ones with a SFS style bar mount. We may do that at some point, but I'm just trying to catch up with the regular stuff first!
Note that if you run a steering damper, you may need to limit your bar sweep (I epoxied washers onto my frame to accomplish this easily), otherwise your SFS clamps may interfere/contact the damper tower clamp.
Feel free to contact me if you want to see the setup I ended up with to run a Scotts steering damper. It was a bit of trial-and-error, but I ended up with a clean setup.
I'll stick it in the mailbox on my way out of the office tonight. Thanks!
Post a reply to: Help identifying Neken SFS triple clamps
