Hey guys need some advice here.
I have a '22 KTM 250SXF. I'm a slow MX racer - typically mid pack in the 60+ Vet Novice class in the SoCal OTMX club. Usual track for me is Glen Helen. I'm about 225lbs in shorts/T-shirt, so I'm guessing about 250 in full gear.
I have the rear set up pretty well - 5.4 spring set to 105mm sag with about 7mm of preload on the spring.
For the forks, I have the JBI DIY kit installed, which consists of a sub valve and a new leaf-spring type mid valve - similar to SSS KYB/A-Kit forks.
My issue is I'm not getting anywhere near full travel, and the forks feel quite harsh when landing from a jump, and very busy in braking bumps going into corners. I don't have a lot of confidence in the corners - it feels like I have a lack of front tire traction.
I checked my travel using the o-rings on my forks, and was several inches from bottoming. Granted at my skill level and age I'm not airing-out jumps - I'll usually land about 1/2 to 3/4 of the way over a table top. But even that feels quite harsh on landing. I was initially running about 145-148 psi in the fork. I lowered it down to 138 last sunday, but even at that I'm still at 3" from full travel. This already seems like too low of a pressure given my weight.
MXA says to keep lowering air pressure until I have about 1 to 1 1/2" of travel left, but I'm hesitant to keep going lower - won't that cause my forks to ride too low in the stroke, which in itself will cause harshness? I t seems I'd have to go down to about 120 or so psi to get another 1 1/2" - 2" of travel - and that just seems way too low. They say to do this before messing with the clickers though. (I'm at 12 out on compression currently)
The person that installed my fork kit did fill my outer fork legs with 280cc of oil in each leg. Manual states 230cc is standard, (+10/-50). Could this be part of the issue? Should I try draining 50cc out and see what happens? I'm also confused about whether to drain oil from both legs, or just the dampening side - I see both ways mentioned.
Thanks for your help
