Hi guys. I have 30 hours riding on my 2018.5 Fc450 rockstar. I can’t seem to find the right feel out of the WP AER 48 forks. I’ve tried multiple air pressures from 130-165. I’m 185lbs.
My issue is a good air pressure without bottoming out. Last weekend I spent the whole practice trying to get the most out of the fork without bottoming out (zips ties to see travel). Found that even getting up to 165psi, I still bottomed out on on the biggest hits.
Right now I’ve got comfortable with compression at 12 clicks out. Manual shows stock at 15 clicks out/sport 10 clicks out. Rebound is set at 10 clicks(which is what husqvarna has for sport/15 standard).
Even preloading I just can’t seem to get the same pop off the face like I did with my showa fork on the 08 crf450r.
Most guys I’ve talked to/forums/keefertesting have all agreed on 151-155psi. Even the guys at my local husqvarna/ktm shop. Bikes great other wise.
I guess my two questions I’m getting at.
1. What air pressure are you guys running with the AER48 fork(psi)?
2. What have you settled on fork settings?
Maybe a little input and similar weight I can find that “pop” that I feel I’m missing in my suspension.
Thanks fellas happy riding
