Dallas, TX
After 35hrs on my 2018.5 rockstar fc450 the clutch slave shit the bed. Everyone knows eventually it’s gonna happen. From talking to friends and hearing others I did pretty well making it to 35hrs before it giving out. Husqvarna fix that shit.
Now which route to go? Which aftermarket slave are you running?
Is KTM slave compatible to the husqvarna? If so, better quality? Brembo? Oberon? What slave is reliable and give me a much longer lifespan.
Yes that’s the way I was going to go
Seal by the piston is blown.. seeing what worked best for other guys
Watched a quick YouTube vid looks simple. Gonna call my dealer Tuesday and pick up the ktm rebuild kit keeping the stock cover. Will post back when I get the slave working again.
Appreciate the input cap
I read online that silicon fluid can eat them up. Then I saw BelRay offers a silicon fluid which maybe people run in the Huskys. Any thoughts?
Output Cyl. Dot Cpl. 27mm
original partnumber 79432061044
superceeded by 79432061144
Make sure you fill the piston with oil where the line goes in. You can manually press the piston to pull oil in, slowly letting it out, making sure there’s no air in the slave it’s self.
~ Hi if your slave has leak, it tends to be the o ring although the bore can have a nick in it. KTM do not list the o ring and want you to buy a new piston! If you need to change it, just pop the slave in a poly bag and give the lever a pull so it pops out. The o ring size is 23.52 x 1.78 which KTM actually uses on another engine part - part no 07700210 or you can use a slightly oversize one at 23.52 x 2.00 if the bore is worn - again KTM part no 0770230020. Use 600 paper to smooth bore if any roughness. Both o rings will cost less than one of your dollars. Hope this helps. Bob.
I ordered the o-ring from local KTM dealer, at first he couldn't find it. will see how the cheap route goes before I spring for a Brembo.... what a disappointment, and with the holiday week he said it could be two weeks before I see it. Ordering it online would be like a $8 shipping charge for a $1.34 part.
Post a reply to: Help, Husqvarna Clutch Slave out
