FL
7/26/2021 9:17pm
Never attempted this method before, but when referring to the service manual it instructs you to place the cases in the oven and heat to around 305-310 and then tapping the case on a solid service to let the bearings fall out. I've already degreased the case and internals and was wondering if anyone has any other tips? Is it going to make my house stink?
The freezer oven trick for installing is just as easy also. I sprayed my bearing casings with wd-40 before installing, can’t remember if it said to do that in the manual or I read it somewhere else
Pull the seal out, then use needle nose pliers to remove the tin bearing retainer. Push the bearings off to one side and remove the inner race, then the bearings. Use the HF slide tool to remove the outer race.
https://www.harborfreight.com/slide-hammer-and-bearing-puller-set-5-pc-…
Post a reply to: Heating cases in oven
