Middletown, CT
11/8/2020 2:49pm
So one of my seats is crumbling and I was gonna send the head off to Millenium Tech to get new seats installed (possibly new valve guides) and a cnc valve job but I noticed that Cylinder works came out with a complete head that has new cam caps, new C630 (nickel/aluminum/bronze) valve seats and valve guides and a CNC valve seat job for $360. Seems like a sweet deal and then I can sell my stock head and make at least a couple hundred back but on the other hand I like the idea of letting the pro's cut the valve seats and they will have my valves so they can vacuum test them and make sure it is getting a good seal. I do have a vacuum tester myself or I could do the liquid trick but if it's not making a good seal I'm sure they would do a way better job then I could at correcting the issue and that way I will know I'm getting a head back that is ready to bolt up and ride. Here's a video on the CRF head but mine is a kx250f however you should get an idea of the decent quality. Also below are the details of the head from their Ad.
Any one that has tried these that could give real life feedback would be great but I'll take other opinions on which way I should go as well cause I'm really torn. Thanks
https://youtu.be/6dHQeVxGUS8
"With each cylinder head you receive the machine matched cam cap(s), C630 valve seats and guides, a competition valve job, shortened valve guides to accept higher lift cams, blended bowls, an un-shrouded combustion chamber, and stock port shapes. This gives you an affordable option to simply get back on track while also including high quality features for building race engines.
These cylinder heads are made in the USA at Cylinder Works facility in Urbandale, Iowa.
Features:
C630 valve seats and valve guides compatible with titanium and steel valves
Shortened valve guides to accept higher lift cams
Performance profiling of the valve seats
Blended bowls
Un-shrouded combustion chamber
Stock port shapes
Machine matched cam caps"
Features:
Blended bowls
Stock port shapes
if I had to redo I would have stuck to oem titanium on both intake and exhaust sides. I have a video of it on youtube, heres's the link https://youtu.be/h6kvAmh7J1Y
Post a reply to: Has anyone tried Cylinder Works Complete aftermarket heads that are U.S. made? They've only been out for a couple years but can't find one review on them!
