Delray Beach, FL
My 2009 KX450F will run fine for about 15 minutes before it shuts off. Once it shuts off I cannot start it back up immediately. I have to wait about 20 or so minutes (maybe to let it cool down?) to kick start it and it'll start right up. Along with this, I noticed when I rev the engine at a high RPM in neutral, the coolant overflow hose spews out coolant, or water... I'm not sure which.
I have read online that the cause could be many things, blown head gasket, bad radiator cap, or other things.... I recently had the head gasket replaced so I doubt it is that.
Will overheating cause the bike to turn off(stall) automatically? Any advice and information would be greatly appreciated.
Something is getting Hot
I would check cams and lubricating system
Make sure water pump impeller is good
Post a reply to: HELP: 09 KX450F Turns off after about 15 minutes of running
