San Diego, CA
4/7/2020 3:50pm
There was a cool thread about greasing bolts recently. Seemed most were in favor of a light coat on all bolts.
But I was curious where y'all stand on grease or Loctite? Let's saying you're doing this job of re-torquing motor mount bolts and hangers. https://www.vitalmx.com/videos/features/OEM-Tech-Honda-Chassis-Retorqui…
Would you Loctite or grease the threads? Would you grease the flanges of the nuts and bolts?
I'm on lockdown so I have time to go all OCD on my bikes! Thanks!
I like blue loctite on my plastic bolts or skid plate bolts.
Other than that i use grease on everything else.
Such as setting the torque wrench to 15ft.lbs. instead of 20ft.lbs. or whatever?
Or just go by feel?
https://luxonmx.com/resources.html
A short story - he once took me out in a Corvette that they let him drive home from work for the evening. It was roughly 6 years later that the same model was offered to the public - he convinced them to let him test the intelligent cruise control for the night. I had lots of fun, he was a great driver.
We use Loctite C5-A anti-seize for our titanium bolts, and we supply some with our parts to ensure everyone is using the correct stuff. The data-sheet is available here:
http://tds.henkel.com/tds5/Studio/ShowPDF/C5-ACBAS-EN?pid=C5-ACBAS&form…
It references a k value (essentially friction value) of 0.27 for an unlubricated bolt and 0.16 for a bolt with anti-seize applied. That's a 40% reduction, hence the 40% reduction in applied torque for the same bolt tension.
The Permatex data sheet (https://441py33rout1ptjxn2lupv31-wpengine.netdna-ssl.com/wp-content/upl…) does indeed say "Reassemble parts using normal torque values.", but it also says that the anti-seize is a lubricant, so I wouldn't trust their instructions for using normal torque values. And in general, I stay away from Permatex as I've had bad luck with their threadlockers in the past. Henkel (Loctite) is my preferred brand by far.
From what has been mentioned above, it sounds like theres an inverse relationship between the clamping force and the amount of friction on the threads. More friction = less clamping & less friction = more clamping.
Remember you need the right about of clamp load. It's like tire pressure, more is not always better and too low is always bad.
Post a reply to: Grease/Loctite bolts on assembly
