Laotto, IN
2011 Kx250f
Ive rebuilt the forks. Have the correct spring rate.
Forks up 7mm (around stock I believe)
55mm of sag (mostly woods riding)
9 out on compression
10 out on rebound
Stock oil weights and volumes.
Rear shock is at 103mm sag forget where the clickers are.
I like how the suspension feels. But I’m getting what I’d call “biting” (handle bars like to tuck entering the corners)
I tried lowering the forks in the triples and did not like that at all front end started washing out.
Any tips as far as clickers, pre load, or sag to help with this but not make the suspension “feel” different?
10 out on rebound
Reduce front end sag a bit.
Also may want to reduce front air pressure a couple of lbs.
I’m running 11 psi on SC5’s. Can I go lower with those? Thought I had read the tire can roll at much lower?
When I get that right it helps my energy a ton too. I have a tendancy to let the bike pull me out of the corner and I hate it! Trying to break that!
I rebuilt the front with a racetech spring and they recommend a 105mm ride height. How do I measure ride height? I couldn’t figure that out so I just set the sag in the front.
Just so I know what I’m feeling for...what reaction should I get out of going a little softer in the rear?
Post a reply to: Front suspension tuning
