Northern California, CA
KTM and Husky use these Formula components on their smaller 2 strokes and for the last 4 years I have spent many hours fighting with the brakes in particular. Rebuilding them, bleeding them constantly, etc. The Nissin brakes on the little Japanese bikes were always worry free for me, change pads and fluid occasionally, that was it. The KTM 85 is vastly superior in every way to say a KX 85 IMO, except for the brakes. They are truly terrible from a reliability standpoint, at least in my experience. Anyone else have a similar experience, were you able to get it resolved?
Its complete garbage,
Front
Change the pistons to stainless steel ones, they dont stuck like the plastic does.
rear
was scared to even change the wheel.. never sure if it going to work when you have pressed the pads apart.
Buy the bigger ktm bikes rear master (holes fit ) and caliper and go up in size on the disc. 220mm? (motomaster makes them to fit ktm 85 wheel)
Make a special brake line at your local shop. hydralic shop
its was upgraded at the 85 2021 model here in europe. (buy the upgraded brakes ?)
working fine now ( second son riding it)
Once you figure out how to bleed the Formula crap it isn’t so bad. Keep good fluid in them & rarely had issues….
Post a reply to: Formula braking and clutch components - unreliable
