Fork oil and upgrading spring rate question
9/12/2021 7:41 AM
Anybody have recommendations for fork oil on a 18 YZ250F? I have about 35hrs or so on the bike and figured it’s time for a fluid change. Also I’m a vet C rider and was wondering if it’s worth it to change the spring rate for a 200lb rider?
EriCS1981
9/12/2021 8:25 AM
5wt oil. I would sure assume the spring rate in the bike from factory is soft for your weight. Try racetech spring rate calculator on their website.
9/12/2021 8:45 AM
Racetech calculator is not right for stock valving. Call a suspension shop what they recommend with stock valving and order it.
Gone:
2006 CRF230F
2008 KTM 200 XC
2017 KTM 250 SX
2019 CRF250R
Current: 2021 YZ250F
9/12/2021 1:36 PM
Yes, call Enzo for springs and oil
9/13/2021 5:20 AM
So I need to upgrade then even at my skill level?
EriCS1981
9/13/2021 6:36 AM
Its not really an upgrade. Is setting the bike up for you so its safe to ride
9/13/2021 10:04 AM
Is it worth to revalve as well?
EriCS1981
9/13/2021 2:24 PM
Edited Date/Time: 9/13/2021 2:26 PM
It's not your skill level, it's your weight.
Right now you suspension is sitting lower in the stroke due to your weight, you may feel harshness due to this.
Personally, I would freshen everything up, shock included. I wouldn't mess with valving yet, the stock valving may work well sprung correctly.
9/14/2021 8:29 AM
Right now you suspension is sitting lower in the stroke due to your weight, you ...more
This. Use the correct spring rate for your body weight; valving is more for your speed. I think the stock valving on the SSS fork is amazing for us mortals.
I use the KYB 01M fork oil in my forks.
Braaapin' aint easy.
9/14/2021 6:53 PM
I spoken with Factory Connection, they said to keep the front fork springs as is, upgrade the rear and go from there.
EriCS1981
