1. Turn compression clickers ALL the way in (lightly bottom)
2. Turn counter-clockwise until you feel a click (detent) and stop, this is your base, or Zero.
3. Turn the clicker counterclockwise and count every click on the way out until it stops turning (lightly top). This is your total adjustable range.
4. Turn clockwise all the way back into Zero.
5.Turn clicker counterclockwise exactly 1/2 the range you'd just counted. Example; 24 clicks out total, turn 12 clicks out now.
6. Repeat on rebound
This give you adjustment either direction you may need it. Cheers!
go to section 4-9, the rear is section 4-16
http://www.crservice.dk/Suzuki%20cross/RM125/RM125K7_01A.pdf
Post a reply to: Fork clickers for rm125
