Orange City, IA
According to the Race Tech spring calculator, my weight calls for one spring rate softer in the forks than is stock. Is this going to be enough to notice or would I just be spending money for no real noticeable effect?
The other would be to go up or down to the closest rate. That will require you to evaluate things...ie, if you ride mostly tracks, you might go to the heavy rate side. Trails? Maybe go with the lighter rate. Hopefully someone will chime in that has more tuning experience and can give more advice.
Post a reply to: Fork Spring Rates?
