1/25/2019 10:18 AM
Edited Date/Time: 1/25/2019 10:19 AM
DaveJ wrote:
Technically you don't have to put new oil in either one. And you don't have to dump any oil out if you're just replacing the seal. There are ways.
Now...that said, maybe you're thinking about servicing the fork at the same time you have them apart. In that case, you will find that the outer fluid is dirtier and in need of replacement more often than the inner chamber oil. This is because nearly all of the "soot" in a fork comes from the spring rubbing on the inside of the lower tube.
When I have been in a hurry, (at the track, between moto's..lol) I have done it without changing any oil.
But yeah, if you have the time, and while you've got the inner chamber out, change the oil in it also. Not that hard.
