Fitting KYB shock onto 2018 & 2020 kx450
Yeti831
UT US
What needs to be done to fit a kyb shock from a 2009 kx450 to a 2018 kx450f, and also a 2020?
Currently have an '18, but may upgrade to a newer model and want to keep my suspension.
Thanks, gang ๐Ÿ‘
mwssquad827
Twin Falls, ID US
5/30/2020 10:42am
Measure eye to eye and compare if they are even close... it should be pretty close... then look at and if itโ€™s different measure clevis..
Iโ€™m assuming you want to just bolt on not get crazy with the modification of the KYB...
Yeti831
UT US
5/30/2020 10:46am
Measure eye to eye and compare if they are even close... it should be pretty close... then look at and if itโ€™s different measure clevis.. Iโ€™m...
Preferably, with as little modification as possible.
I can't find them but I remember seeing threads on the prior gen bikes. Haven't seen anything pop up for them on the newer bikes though.
mx317
TN US
5/30/2020 11:52am
I used a 2012 on my 16 and it was a bolt on.
Yeti831
UT US
5/30/2020 12:31pm
Oh nice. I figured there wasn't any difference from '08 or '09 up to '18.
So sounds like I'll be ok with my current ride once the shock arrives.
Still curious about the '19 and '20 models. I shouldn't have ridden one ๐Ÿ˜ญ
mwssquad827
Twin Falls, ID US
5/30/2020 12:55pm
Ya might as well just try to bolt her up.... Hope it works out for ya๐Ÿ‘๐Ÿป๐Ÿค™๐Ÿป
dancolvin633
Plumas Lake, CA US
2255th
5/30/2020 2:22pm
Not going to work. Old shock will
Not fit on the new chassis, unless you want to make a huge mess and start destroying the frame and air box
Yeti831
UT US
5/30/2020 5:18pm
Not going to work. Old shock will Not fit on the new chassis, unless you want to make a huge mess and start destroying the frame...
So if I upgrade to a newer frame, better off just selling it with the bike?
dancolvin633
Plumas Lake, CA US
2255th
5/30/2020 9:13pm
If it were me Iโ€™d sell the suspension separate and put the stock stuff on the bike... you will get more out of it that way.
dmm698
NY US
6/2/2020 11:26am
I dont know what KYB shock you're talking about but i'm assuming its a "kit" style shock if you have such a hard on to hang onto it.
06-18 is the same as far as physical fitment goes.
06-18 Showa KIT/ works body will not fit on the new frame without some clearancing, and so much so shops like PC have just been retrofitting all the kit internals into the production body. 19/20 shock is also shorter. Stock the 19-20 come with the larger comp adjuster like showa kit shocks. I have a 06-18 kit body sitting at my house because all the guts are in my stock 19 body.
You could run the KYB forks on the 19-20 but you'd need to use the older front hub as the 19-20 axle is larger DIA. Not worth it IMO as the stock 49mm showas are just as good if not better than the works KYB IMO, they are essentially kit forks from the manufacturer for most intents and purposes.
Post a reply to: Fitting KYB shock onto 2018 & 2020 kx450
