I’ve done it in a pinch, yes it works; do I recommend it? no... when you file the basket you open up the tolerances between the fibers and basket Which cause the basket to notch quicker... obviously, the correct way is to replace the basket...
You can file them, but understand that you are placing uneven pressure on the fiber plate fingers and the notches will return or you may break a fiber or 2. DON'T DO IT!
Once is fine but don’t file down so far as to remove entire grove. As mentioned above by reliable sources... it will come back quicker so order a new basket ASAP while you get a few more rides out of it.
Post a reply to: Filing your worn clutch basket
