Figure proper spring rate
2/5/2019 6:51 AM
So I know static sag should be between 30 & 40 mm, with race sag at 100mm if the spring is right! ( if you have 40mm static & only 95 race sag then you need to go up a rate)
My question is , so these guys running 108 to 110 mm of race sag! Is the same formula used to determine the proper spring rate?
2/5/2019 8:14 AM
DB505 wrote:
So I know static sag should be between 30 & 40 mm, with race sag at 100mm if the spring is right! ( if you have 40mm ...more
You would go down a rate (softer) with 40mm static and 95mm race sag. 105mm is a good starting point and is figured the same way (30-40mm static).
2/5/2019 11:12 AM
I think you are mistaken, but thanks for the response
2/5/2019 11:45 AM
I am not mistaken. Here is a little tutorial on spring rates.
https://motocrossactionmag.com/bones-bacon-on-suspnsion-static-sag-versus-spring-rate/
2/5/2019 11:53 AM
MX317 is correct. If you're at 95 and trying to get to 100 you would loosen your adjuster, less preload. This would in-turn create more free sag (if you're at 40 it would foreseeably go to 45). Meaning your spring rate is too stiff and must be softened. Here is a link you might want to read.
2018 KX450F
2005 KX250
2003 KDX 220
1984 KX 80
1982 RM 80
1980 RM 80
1977 XR 75
1969 Honda Mini 50
2/5/2019 11:54 AM
Edited Date/Time: 2/5/2019 2:40 PM
Kind of funny we both posted the same link, I guess I should type a little faster. lol
2018 KX450F
2005 KX250
2003 KDX 220
1984 KX 80
1982 RM 80
1980 RM 80
1977 XR 75
1969 Honda Mini 50
2/5/2019 12:03 PM
I stand corrected! Thanks!
