Fc250 battery issues
1/12/2020 8:42 PM
I have 2017 husky FC 250 and the battery went dead to start it. I put a new battery in it and it goes dead almost immediately. Starts fine the first time then I shut it off try to restart and it's dead. Do you know what the problem might be cuz I don't know s*** about these four strokes and electric starts and new motocross bikes
1/13/2020 5:42 AM
Is the battery charging while the bike is running?
1/13/2020 9:14 AM
I'd say no. Start it, shut off, battery deac
1/13/2020 11:55 AM
Check your starter relay. Almost every thing on this bike goes through it. Be sure all the connections are clean and tight and that the fuse is good. Also check all ground straps on the bike as if they are rusty or dirty you will not have a good ground and thus it will not charge. If all this is good then test the stator out put. If good then look at the rectifier .
