Rancho Cucamonga, CA
Ran when parked, really. I washed it, ran it for 5 minutes and parked it. Today at State Fair MX it's deader than RBG.
Battery is 2 months old and has 13.6 volts.
Starter works when jumped directly to battery. Battery cuts down to 11.42 volts which is good.
10a Fuses in the relay are good.
I cleaned the battery connectors at the track. Worked them a little with a fine nail file.
I pulled the starter button off but didn't see anything obvious.
I intend to pull the tank and start tracing wires to clean and dielectric grease all connectors.
I looked at a couple youtube vids but they were pretty generic.
I don't pressure wash so I don't think I've got too much water into anything.
What have you guys with Husky/KTM got that might help?
Thanks.
Thanks.
The fuse in the starter relay was bad. Not blown, just not passing current. In a visual check, it looked fine. On a multi tester it was bad.
The contacts for the harness that connects to the relay was kind of nasty so I cleaned those up.
The pin in the the e-start button has been mickey moused. I could probably ride tomorrow since I know what it takes to get it started now.
It's all back together with dielectric grease now.
My bike was fixed with a second new Husqvarna relay.
Post a reply to: FC450 No Crank, No Start
