Venado Tuerto
AR
1312th
12/7/2018 7:22am
Hi guys, a friend of mine bought recently a 2015 FC 250. Today we were trying to bleed the clutch and now when you put the bike into gear it dies because the clutch does not disengage at all. It was working before we try to bleed it, so I'm sure it has nothing to do with worn disks, notched basket,etc. Any suggestions? Thanks.
Did you ever pull the clutch slave off the engine? Wonder if you damage the o ring seal?
I add an extra thrust washer to the mushroom that takes up slack at the lever. You don’t want to add too much because then the clutch will slip. So I’ll might be trial and error to see how far you can push it.
Post a reply to: FC 250 clutch not disengaging
