Just got my engine back from EG. What are the baseline jetting changes any of you have used. I'm just looking for a starting point with the stock carb.
Just got my engine back from EG. What are the baseline jetting changes any of you have used. I'm just looking for a starting point with...
IMO, the stock duel taper series needles that Yamaha uses in the 250 make the 295 engines hard to ride. If it were my bike, I would use a Suzuki NECJ #3 or NEDJ #2 needle, with a 40 pilot, and 168 or 165 main jet, along with a 40 power/leak jet. This will get you going safely in the right direction.
A #8 slide works very well the 295 configuration, but will also require a new non spring loaded cable holder, unless you cut your current oem #7 slide into a #8.
Call Eric. I bought a complete cylinder and top end for my YZ134 that didn't come directly from him, but was supposed to be his work. He emailed me the jetting spec in a couple of days.
Lots of info on thumpertalk on these kits too.
Post a reply to: Eric Gorr 2002 YZ295
