Zimbabwe, MA
1/10/2021 2:45pm
Building a garage with concrete floor and want to epoxy next year once the concrete is fully cured.
Any of you use the Rustoleum product line? If so, how has it held up after years of abuse? Did you use the initial product or did you use the newer "Rocksolid" product?
Thanks!
Thanks!
Is it slippery?
Durability has been very good. Numerous items dropped on the floor with good chip resistance.
Yellowing has been an issue.
I thought the prep when the coatings went on was excellent and no doubt why it has stuck so well.
How do floor epoxies generally hold up to such chemical exposure?
We didn’t do the epoxy, the previous homeowner did it before moving out so I can’t attest if the prep and everyday was done correctly, but as far as coolant, contact cleaner, and brake fluid everything always wiped up easy and never stained or peeled other than the gas incident, but like I said we could possibly chalk that one up possible shitty prep work or install.
Post a reply to: Epoxy Flooring - Rustoleum Holding Up Well?
