AT
1/27/2021 4:22pm
After a Winter Rebuilt on my KTM 300 SX 19 i make a 20 minutes Test Ride yesterday. It runs lean but Engine Sounds good . Outside Temperature was close to Zero.
As i stop at the Garage it revs out and was not able to stop it by Killswitch .
I dissconect the Spark Plug Connector and it doesn‘t stop after i switch of fuel it takes Two minutes to stop
Before it happens i did the following Mods:
New Throttle Cable
New #4 Mikuni Slide (Leftover Honda CR 125)
Slide and Drain Plug Mod according to Thumpertalk
New Aluminium Throttle Grip
I thought it was a stuck Throttle but i found nothing today when i dissasemble .
Could it have something to do with the Slide Mod ?Jetting was according to KTM Manual
Appreciate every help
New Throttle Cable
When the engine runs away like that, put it in 3rd or 4th gear, hold the brakes hard, and slowly let the clutch out.
Good Idea to shift in fourth and kill the Engine it was a scary Moment when a 300 revs Up that high but for the next time i am prepared 😂
Too much fuel some how. Air screw position
It likely ran until the float bowl was empty.
Crank seal , that plug doesn't indicate a lean 2stroke. I think it was overly rich and
you could built up alot of fuel in the crank case. You burned that off with a leaking crank seal. Possibly
Maybe your petcock wasnt actually off possibly.
It could only keep running after you pull off the plug and shut off the gas if it has it other sources of both air and fuel
Post a reply to: Engine Overrev run hot after Carb Rebuilt KTM 300
